You are here: PSPad forum > Bug report / Hlášení chyb > Re: PSPad 4.5.9 can no longer rewrap selected lines to right margin
Posted by: therium | Date: 2015-08-02 22:20 | IP: IP Logged
PSPad 4.5.9 (2600) on Windows 8.
In 4.5.8 when I select multiple consecuritive lines, I usually hit CTL-K to rewrap them to the right margin. But in 4.5.9 when I select multiple lines in a text file, the menu item Format, Block Format, Reformat lines is disabled/grayed out.
This happened when I updated PSPad on my Win 8 PC. Was some setting reset, or is this a bug? How do I fix this?
Thank you.
Posted by: pspad | Date: 2015-08-03 04:11 | IP: IP Logged
Please ensure that WordWrap is off (menu View or toolbar button or Ctrl+W). When text is wrapped, you can't use reformat paragraph from the Format menu
Posted by: therium | Date: 2015-08-03 12:16 | IP: IP Logged
Ah, that was the problem. Wordwrap was on.
Thanks.
