You are here: PSPad forum > Bug report / Hlášení chyb > Re: PSPad.exe - application error EAccessViolation 004FF114
#1 PSPad.exe - application error EAccessViolation 004FF114
Posted by: maguslod | Date: 2015-06-09 22:22 | IP: IP Logged
I am running Windows 10x64 build 10130 (it has happend in prior builds) and everytime I try to close a character set (IE <div ) and it crashes. Here is the error log.
Quote:
Exception class:
Exception address:
Stack list, generated 6/8/2015 7:45:27 PM
Please do not post such long reports to the forum.
Send them to Jan by mail (See PSPad > Help > About)
Thank you.
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 4.5.9 (2600)
System : Windows 8 Professional x64, Version: 6.2, Build: 23F0,
Processor: AMD, AMD FX(tm)-8150 Eight-Core Processor , 4500 MHz MMX
Display : 1920x1080 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit "_1"
Here is an image of the error.
Link to Image- 76.86 KB
I tried updating to the latest version, uninstalling and doing a fresh load, loading only core files, but still get the error. Thank you in advanced for any help.
-Magus-
Edited 1 time(s). Last edit at 2015-06-20 14:26 by Stefan.
#2 Re: PSPad.exe - application error EAccessViolation 004FF114
Posted by: pspad | Date: 2015-06-10 03:46 | IP: IP Logged
The problems started with Windows 8.1. The problem is combination of highlight matching brackets + wordwrap mode
If you switch off WordWrap mode (Ctrl+W), the problem disappeared.
I tested it with latest Windows 10 build and it doesn't happened to me. So for me it's hard to find a reason. The problem is joined with page drawing.
#3 Re: PSPad.exe - application error EAccessViolation 004FF114
Posted by: maguslod | Date: 2015-06-10 13:25 | IP: IP Logged
Thank you very much, I will test this out later. I love PSPad for my coding and the last few days have been a headache fighting crashes.
-Magus-
#4 Re: PSPad.exe - application error EAccessViolation 004FF114
Posted by: mustafa2116 | Date: 2015-09-29 20:15 | IP: IP Logged
www.dropbox.com PSPad.exe - application error EAccessViolation 004FF114 FİX
İmage view
Link :www.dropbox.com
TR.
Uygulamanın Karakter tamamlama özelliği kapatıldığında sorun düzeliyor.
