You are here: PSPad forum > Bug report / Hlášení chyb > Re: Current portable version broken?
Posted by: rovf | Date: 2015-04-28 12:41 | IP: IP Logged
I just downloaded the version
4.5.9 (2600)
(ZIP File), verified the checksum and unzipped everything into a freshly created directory (c:\p\pspad). Clicking on PSPad.exe did not start the editor, but opened a dialog box complaining that the file could not be accessed!
This image shows the Explorer window from where I started the file:
This image shows the error message:
The operating system used is Windows 7.
Since I have nearly all my programms organized within C:\p\SOMEDIRECTORY the error is unlikely related to missing permissions for this directory. Could it be, that the current portable version of PsPad is broken?
Ronald Fischer (Germany)
Posted by: pspad | Date: 2015-04-28 13:03 | IP: IP Logged
Portable and installer are same.
Try to download current build from Developer forum and replace existing files in your folder.
