You are here: PSPad forum > Bug report / Hlášení chyb > Re: Cannot open more files together
Posted by: lorife | Date: 2015-04-27 07:27 | IP: IP Logged
I've been using PSPad for a long time, I'm now using the last version on Windows 7 64bit.
If I select 4-5 files from windows explorer, right click them and then click "pspad", it will open just one file.
can you please fix it?
thank you!
Posted by: pspad | Date: 2015-04-27 07:33 | IP: IP Logged
What form of Explorer integration do you use?
Open program settings / System integration, disable integration and confirm.
Enable integration and confirm.
If you use current PSPad version, I suggest you to use integration with DLL library.
Posted by: lorife | Date: 2015-04-27 15:39 | IP: IP Logged
you're right.
Using the registry option it does not work. Using the DLL option it works!
