You are here: PSPad forum > Bug report / Hlášení chyb > Re: Code explorer doesn’t handle function parameters on new line
#1 Code explorer doesn’t handle function parameters on new line
Posted by: m2u_germany | Date: 2015-03-28 17:06 | IP: IP Logged
I just noticed a minor issue with the Code Explorer: if you declare your function like this:
function doStuff (
···paramA,
···paramB,
···paramC
instead of:
function doStuff (paramA, paramB, paramC) {
the Code Explorer doesn’t recognize the function’s parameters correctly. It only displays “function doStuff(” without parameter listing and closing bracket. So in essence parameters on a new line are left out obviously.
Happened in a JavaScript file but I guess it concerns other languages too. It’s only a minor issue but maybe you can take a look at this some time.
Thanks a lot for your continuous efforts on this great software and have a nice weekend!
Matthias
P. S.: Version is 4.6.0.2655 btw.
Edited 1 time(s). Last edit at 2015-03-28 17:12 by m2u_germany.
#2 Re: Code explorer doesn’t handle function parameters on new line
Posted by: pspad | Date: 2015-03-28 18:08 | IP: IP Logged
Code parser parse code line by line.
