You are here: PSPad forum > Bug report / Hlášení chyb > Re: Clip list truncated for some languages
Posted by: mihau | Date: 2015-03-08 18:02 | IP: IP Logged
I did extensive searches here in the forum but couldn't find anything so I assume what I will now describe is a bug:
as of lately, Clip lists for certain files seem to be truncated - I post two examples below; this happens for both "fresh installs" as well as an old one and current stable version as well as the latest developer build.
(I checked the corresponding *.def files - they are fine and continue way below what is shown in the clip window)
this only happens for certain languages, e.g. Python and PHP, but not Perl or HTML etc.
Posted by: pspad | Date: 2015-03-08 18:24 | IP: IP Logged
Hello, this isn't truncated, but intentionally limited. If you start wite, list will be more and more narrowed.
It has no sense to show thousand items in the list.
Open PHP and start to write: cpdf_p
when you start write, you will see how to list will shows you only items started what you wrote
Posted by: mihau | Date: 2015-03-09 14:12 | IP: IP Logged
ah now I understand, my bad
thanks for your time and the explanation!
