You are here: PSPad forum > Bug report / Hlášení chyb > key map ALT+/ does not work after restart
#1 key map ALT+/ does not work after restart
Posted by: rholmqvist | Date: 2014-12-12 15:57 | IP: IP Logged
I set the autocomplete to Alt+/ and it works. When I exit pspad and restart, Alt+/ does not work. According to the menu, Alt+/ is still assigned, but it does not work. If I set the kay mapping to Alt+/, it will start working until I restart pspad.
I do not have the same problem when I use other key mapping assignments. It appears that pspad does not load the key mappings correctly on startup when it has "Alt+/". It is probably treating the "/" in a special way compared to other chars.
[Tools]
...snip...
aAutoCompl=Alt+/
#2 Re: key map ALT+/ does not work after restart
Posted by: pspad | Date: 2014-12-12 16:07 | IP: IP Logged
I guess you installed PSPad as portable or unpack portable version into Program files.
PSpad has no right to write there, so there is no possibility to save configuration.
Run PSpad as administrator (using right mouse button), go to program settings / System and check Multiuser environment. Restart PSpad.
