You are here: PSPad forum > Bug report / Hlášení chyb > Using Multiple Displays
Posted by: pspad | Date: 2017-02-06 07:47 | IP: IP Logged
CieraBrier:Freeman:Jan, I wrote small sample, but cannot test it, because I have only one monitor:
TMainForm = class(TForm)
protected
procedure WMWindowPosChanged(var Msg: TWMWindowPosChanged); message WM_WINDOWPOSCHANGED;
end;procedure TMainForm.WMWindowPosChanged(var Msg: TWMWindowPosChanged);
begin
inherited;
if not (csLoading in ComponentState) then
with Msg.WindowPos^ do
MoveWindow(Application.Handle, x, y, cx, cy, True);
end;
This caused wrong Window border on Windows 10
Posted by: lucileburt | Date: 2017-09-06 17:02 | IP: IP Logged
sasumner:I noticed a multiple displays issue recently regarding what appears on which screen; maybe it is a known issue. I am using pspad 4.5.9 (2512).At my desk I have a two-external-monitor setup with a notebook PC in a docking station; I keep the notebook's lid closed so that its screen isn't used. I run pspad's main window on the secondary monitor (the one without the Win7 taskbar at the bottom). This is the normal situation and all is good.
When I undock my PC and use it with its single screen, pspad's main window will "move" there after undocking (this is correct). When I do a replace the find/replace dialog comes up fine and I enter my search and replace text, but if I check the Prompt on Replace checkbox (as I usually do), the prompt dialog that should show upon each find match is not visible. I can still press Y or N (or Esc) for each found match, so I think the prompt dialog is actually there, it is just still on the second screen (which isn't there at this point).
This happen to me one.
although i came back from a party
Posted by: AnthonyBeavor | Date: 2017-12-14 15:03 | IP: IP Logged
bkneepkens:I experienced the same problem with a Delphi application. The solution proved to be as follows.
I don't know what Delphi version was used to build PSPad, but this is what I did in Delphi 7:1. In FormCreate, hide the VCL-controlled taskbar button and assign an handler for the OnActivate event:
procedure TfrmMain.FormCreate(Sender: TObject);
var
windowLong: integer;begin
Application.OnActivate := OnApplicationActivate;// Hide the taskbar button for the zero-size Application window.
// We'll let Windows deal with taskbar buttons and not the VCL.
windowLong := ((GetWindowLong(Application.Handle, GWL_EXSTYLE) and (not WS_EX_APPWINDOW)) or WS_EX_TOOLWINDOW);
SetWindowLong(Application.Handle, GWL_EXSTYLE, windowLong);
end;2. Implement the OnActivate event as follows:
procedure TfrmMain.OnApplicationActivate(Sender: TObject);
begin;
// Set the focus to the currently visible form. This may not always
// happen automatically because we're bypassing part of the VCL.
try
Screen.ActiveForm.SetFocus();
except
end;
end;3. Override CreateParams to show a taskbar button:
procedure CreateParams(var Params: TCreateParams); override;procedure TfrmMain.CreateParams(var Params: TCreateParams);
begin
inherited CreateParams(Params);// Show a taskbar button
params.ExStyle := (params.ExStyle or WS_EX_APPWINDOW);// Set the desktop as the window's parent.
// Without this the taskbar button will still appear, but then it
// won't move to Windows 10's second taskbar if the window is moved
// to a secondary monitor. (This is probably also true for Windows 8,
// but I haven't been able to test that).
params.WndParent := GetDesktopWindow();
end;4. Handle the WM_SYSCOMMAND message to support minimize/restore:
procedure WMSysCommand(var msg: TWmSysCommand); message WM_SYSCOMMAND;procedure TfrmMain.WMSysCommand(var msg: TWmSysCommand);
begin
// Bypass the VCL and let the Windows API
// handle minimize/restore functionality.
case (msg.CmdType and $FFF0) of
SC_MINIMIZE: begin
ShowWindow(Self.Handle, SW_MINIMIZE);
msg.Result := 0;
end;
SC_RESTORE : begin
ShowWindow(Self.Handle, SW_RESTORE);
msg.Result := 0;
end;
else begin
inherited;
end;
end;
end;Hmm, the forum removes indentation, even within code tags... oh well. Hope this helps
Although I am quite sure it wont solve the problem this is a brilliant idea, cheers
Posted by: AnthonyBeavor | Date: 2017-12-14 15:09 | IP: IP Logged
Sorry for my pessimism anyway. It may work finally
phenq-fr.com
Posted by: pspad | Date: 2017-12-14 17:41 | IP: IP Logged
Thank you very much, I will test it. Just now I am fighting with themes - they consume all messages
Edited 1 time(s). Last edit at 2017-12-14 17:41 by pspad.
Posted by: Gabriel_ACE | Date: 2017-12-19 17:47 | IP: IP Logged
I have 3 monitor
do you need help testing it?
Best Regars!
Posted by: BillySan | Date: 2018-06-21 14:51 | IP: IP Logged
AnthonyBeavor:Sorry for my pessimism anyway. It may work finally![]()
It works mate, guaranteed
Posted by: FeliciaGardner | Date: 2021-08-27 23:40 | IP: IP Logged
PaGomersall:Jan,
In current development build 2743 situation is still the same. Have you any update on finding a fix to this?
Pete
As a developer as well.. I used to have multiple monitors, but a history of slipped discs and bad neck forced me down to one. I like it more after getting used to it. My pain is less as well
Posted by: FeliciaGardner | Date: 2021-08-30 11:03 | IP: IP Logged
well i had to look this thread is very old.
