You are here: PSPad forum > Bug report / Hlášení chyb > Re: Using Multiple Displays
Goto Page: Previous1 2 3
#21 Re: Using Multiple Displays
Posted by: pspad | Date: 02/06/2017 07:47 | IP: IP Logged
Jan, I wrote small sample, but cannot test it, because I have only one monitor:
TMainForm = class(TForm)
procedure WMWindowPosChanged(var Msg: TWMWindowPosChanged); message WM_WINDOWPOSCHANGED;
procedure TMainForm.WMWindowPosChanged(var Msg: TWMWindowPosChanged);
if not (csLoading in ComponentState) then
with Msg.WindowPos^ do
MoveWindow(Application.Handle, x, y, cx, cy, True);
This caused wrong Window border on Windows 10
#22 Re: Using Multiple Displays
Posted by: lucileburt | Date: 09/06/2017 17:02 | IP: IP Logged
I noticed a multiple displays issue recently regarding what appears on which screen; maybe it is a known issue. I am using pspad 4.5.9 (2512).
At my desk I have a two-external-monitor setup with a notebook PC in a docking station; I keep the notebook's lid closed so that its screen isn't used. I run pspad's main window on the secondary monitor (the one without the Win7 taskbar at the bottom). This is the normal situation and all is good.
When I undock my PC and use it with its single screen, pspad's main window will "move" there after undocking (this is correct). When I do a replace the find/replace dialog comes up fine and I enter my search and replace text, but if I check the Prompt on Replace checkbox (as I usually do), the prompt dialog that should show upon each find match is not visible. I can still press Y or N (or Esc) for each found match, so I think the prompt dialog is actually there, it is just still on the second screen (which isn't there at this point).
This happen to me one.
although i came back from a party
#23 Re: Using Multiple Displays
Posted by: AnthonyBeavor | Date: 12/14/2017 15:03 | IP: IP Logged
I experienced the same problem with a Delphi application. The solution proved to be as follows.
I don't know what Delphi version was used to build PSPad, but this is what I did in Delphi 7:
1. In FormCreate, hide the VCL-controlled taskbar button and assign an handler for the OnActivate event:
procedure TfrmMain.FormCreate(Sender: TObject);
windowLong: integer;
Application.OnActivate := OnApplicationActivate;
// Hide the taskbar button for the zero-size Application window.
// We'll let Windows deal with taskbar buttons and not the VCL.
windowLong := ((GetWindowLong(Application.Handle, GWL_EXSTYLE) and (not WS_EX_APPWINDOW)) or WS_EX_TOOLWINDOW);
SetWindowLong(Application.Handle, GWL_EXSTYLE, windowLong);
2. Implement the OnActivate event as follows:
procedure TfrmMain.OnApplicationActivate(Sender: TObject);
// Set the focus to the currently visible form. This may not always
// happen automatically because we're bypassing part of the VCL.
3. Override CreateParams to show a taskbar button:
procedure CreateParams(var Params: TCreateParams); override;
procedure TfrmMain.CreateParams(var Params: TCreateParams);
inherited CreateParams(Params);
// Show a taskbar button
params.ExStyle := (params.ExStyle or WS_EX_APPWINDOW);
// Set the desktop as the window's parent.
// Without this the taskbar button will still appear, but then it
// won't move to Windows 10's second taskbar if the window is moved
// to a secondary monitor. (This is probably also true for Windows 8,
// but I haven't been able to test that).
params.WndParent := GetDesktopWindow();
4. Handle the WM_SYSCOMMAND message to support minimize/restore:
procedure WMSysCommand(var msg: TWmSysCommand); message WM_SYSCOMMAND;
procedure TfrmMain.WMSysCommand(var msg: TWmSysCommand);
// Bypass the VCL and let the Windows API
// handle minimize/restore functionality.
case (msg.CmdType and $FFF0) of
ShowWindow(Self.Handle, SW_MINIMIZE);
msg.Result := 0;
SC_RESTORE : begin
ShowWindow(Self.Handle, SW_RESTORE);
msg.Result := 0;
else begin
Hmm, the forum removes indentation, even within code tags... oh well. Hope this helps smiling smiley
Although I am quite sure it wont solve the problem this is a brilliant idea, cheers
#24 Re: Using Multiple Displays
Posted by: AnthonyBeavor | Date: 12/14/2017 15:09 | IP: IP Logged
Sorry for my pessimism anyway. It may work finallyyawning smiley
#25 Re: Using Multiple Displays
Posted by: pspad | Date: 12/14/2017 17:41 | IP: IP Logged
Thank you very much, I will test it. Just now I am fighting with themes - they consume all messages sad smiley
Edited 1 time(s). Last edit at 12/14/2017 17:41 by pspad.
#26 Re: Using Multiple Displays
Posted by: Gabriel_ACE | Date: 12/19/2017 17:47 | IP: IP Logged
I have 3 monitor
do you need help testing it?
Best Regars!
