You are here: PSPad forum > Bug report / Hlášení chyb > Re: Set focus to code doesn't!
Posted by: gf_gollum | Date: 2014-10-22 13:41 | IP: IP Logged
When using the code explorer - even with "set focus to code" enabled - if you double click on a function and then use the scroll wheel - its still the code explorer window that scrolls - not the code.
Tiny point - but irritating
Posted by: pspad | Date: 2014-10-22 14:57 | IP: IP Logged
If you have third button activated (pressed), click in code explorer will return focus to document and mouse will scroll in document
Posted by: gf_gollum | Date: 2014-10-31 08:17 | IP: IP Logged
Well I usually use a trackball - doesn't have a middle button, but I plugged in a regular mouse (scroll wheel = 3rd button right?) -- and that button didn't do anything at all. Config issue? user error?
Posted by: gf_gollum | Date: 2014-10-31 08:27 | IP: IP Logged
Hardware error..
Get a working mouse out of the cupboard rather than a broken one and it works just fine.
Thanks
Posted by: pspad | Date: 2014-10-31 08:29 | IP: IP Logged
I am glad you have solved your problem.
