You are here: PSPad forum > Bug report / Hlášení chyb > [2503] slow to start and file drag&dropping doesn't work any more
Posted by: doctorlai | Date: 2014-09-21 12:34 | IP: IP Logged
1. The pspad takes longer to start (the splash window).
2. I cannot drag and drop files into pspad anymore.
Posted by: pspad | Date: 2014-09-21 14:14 | IP: IP Logged
Slow start can be caused several ways:
1. delete DLL files from PSPad folder if you don't use FTPS connection
2. disable scripting support (program files / System) if you don't use scripts in PSPad
To your second point. Drag/drop into PSPad is working. How do you do Drag/drop? Describe it step by step please
Posted by: xspiky | Date: 2014-09-24 14:18 | IP: IP Logged
Try old build 2453, it's last fast version for me.
Posted by: doctorlai | Date: 2014-09-24 16:59 | IP: IP Logged
The drag and drop used to work in previous version.
I just drag a text file to the pspad, the cursor shows a 'plus' but when i release my mouse, it doesn't load into pspad. it just doesn't work.
my system is Win8, 64bit
Posted by: pspad | Date: 2014-09-24 17:14 | IP: IP Logged
doctorlai:The drag and drop used to work in previous version.I just drag a text file to the pspad, the cursor shows a 'plus' but when i release my mouse, it doesn't load into pspad. it just doesn't work.
Tested with current version and it works for me.
I dragged file from Windows explorer and dropped it into empty (grey) PSPad and to open file. Both cases open file in PSPad.
The only way I blocked is way when you use PSpad open dialog and drag/drop file from this dialog into PSPad. But this is totally cockeyed way how to drag/drop file. It caused problem, because Open dialog is modal.
