You are here: PSPad forum > Bug report / Hlášení chyb > slow start (not SSL problem) but start-up splash screen (solved)
#1 slow start (not SSL problem) but start-up splash screen (solved)
Posted by: xspiky | Date: 2014-09-16 12:58 | IP: IP Logged
PSPad is starting too slow, after looking with process explorer I found that break for 2s with this:
14:31:34,5411359 PSPad.exe 11288 CreateFileMapping C:\Windows\SysWOW64\cs-CZ\msctf.dll.mui SUCCESS SyncType: SyncTypeOther
14:31:36,5484155 PSPad.exe 11288 CreateFile C:\progs\pspad\RICHED20.DLL NAME NOT FOUND Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a
14:31:36,5487525 PSPad.exe 11288 CreateFile C:\Windows\SysWOW64\riched20.dll SUCCESS Desired Access: Read Attributes, Disposition: Open, Options: Open Reparse Point, Attributes: n/a, ShareMode: Read, Write, Delete, AllocationSize: n/a, OpenResult: Opened
It'is only my problem?
Radek
Edited 1 time(s). Last edit at 2015-08-31 09:56 by Stefan.
#2 Re: slow start (not SSL problem)
Posted by: pspad | Date: 2014-09-16 13:19 | IP: IP Logged
I am currious where this line cames from:
I don't understand, why your system is trying to create file RichEd20.dll. It's system library located in \Windows\SysWow64 and \Windows\System32 folders
I will try to investigate it
#3 Re: slow start (not SSL problem)
Posted by: xspiky | Date: 2014-09-17 06:54 | IP: IP Logged
It's simple, I have installed c:\progs\pspad\PSPad.exe , so it's try first Exe path for searching DLL.
#4 Re: slow start (not SSL problem)
Posted by: xspiky | Date: 2014-09-18 08:36 | IP: IP Logged
I tried old versions and this is result:
until version
Build 2453 - fast start (<1s) (http://forum.pspad.com/read.php?6,60198)
starting with
Build 2455 - slow start (>3s) (http://forum.pspad.com/read.php?6,60628)
thank you
Radek Cervinka
#5 Re: slow start (not SSL problem)
Posted by: poulicek | Date: 2015-08-03 20:04 | IP: IP Logged
I've just run into the same problem and solved it by simply disabling the start-up screen (version 4.6.0)
The difference is tremendous, the start-up time decreased from couple of seconds the half a second. This bug/feature is really misfortunate, just because of this I've been seeking an alternative editor until I managed to overcome the problem.
Edited 1 time(s). Last edit at 2015-08-03 20:05 by poulicek.
#6 Re: slow start (not SSL problem)
Posted by: vitexikora | Date: 2015-08-30 12:45 | IP: IP Logged
same problem, same solution.
the startup is now 10X FASTER.
please, this should be a default setting or the slowness of the splashscreen should be resolved. I was even thinking of trying a different editor, just because how slow it was. Im starting it like 5-20 times a day.
#7 Re: slow start (not SSL problem)
Posted by: pspad | Date: 2015-08-30 12:57 | IP: IP Logged
There were intentional delay showing splash screen.
I modified SplashScreen behavior to don't delay start of program.
I did some other modification too, I hope you will be kindly surprised
#8 Re: slow start (not SSL problem)
Posted by: vitexikora | Date: 2015-09-01 21:59 | IP: IP Logged
Awesome! Thanks.
