You are here: PSPad forum > Bug report / Hlášení chyb > Error occured
Posted by: u3totu | Date: 2014-07-09 16:45 | IP: IP Logged
Exception description:
It happens always when i try to type <br />
I put cursor behind </table>, put "<", it creates <>, then I pres "b" and it crashes...
It has happened several times.. I use Windows 8.1 x64 (log says XP x64, that is not correct), setting compatibility to "Windows 7 or XP SP3 doesn't help.
Možná bych měl aktualizovat PSPad.
Díky.
Aleš
UPDATE: New version (4.5.8 2485) works perfectly so far...
Takže už možná není třeba řešit. ;)
Exception address: 0
Stack list, generated 8. 7. 2014 0:01:56
Thanks for the report,
but please do not post such lists to the forum,
rather send it to Jan by mail (see Help > About)
Thank you.
Program : C:\Portable\PSPad\PSPad.exe 4.5.8 (2463)
System : Windows XP Home Edition x64, Version: 5.1, Build: A28, Service Pack 3
Processor: Intel, Intel(R) Pentium(R) CPU 2020M @ 2.40GHz, 2400 MHz MMX
Display : 1366x768 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit ""
"_3"
Access violation at address 004FDD84 in module 'PSPad.exe'. Read of address FECD158C.
Exception address: 004FDD84
Thank you.
TPSSynEdit ""
"_3"
Edited 1 time(s). Last edit at 2014-07-14 17:55 by Stefan.
