You are here: PSPad forum > Bug report / Hlášení chyb > Save new file
Posted by: count.negative | Date: 2014-04-30 16:34 | IP: IP Logged
I have a feature request for this super cool editor that I'm using now for over 8 years. (Thanks for this amazing work).
PsPad is in my path so I can do:
pspad test.txt
the test.txt file is not existing yet! So PsPad opens and I can edit text in an empty file. Then, when I want to save this, PsPad asks me about the name and the place where the new file should be saved. But I want it to be saved as text.txt in the current folder where I started pspad!
If I do a copy con text.txt ^z in the still open commandline, then the save action (ctrl-s) is working like expected.
So maybe you could implement that if a file doesn't exist if it't opened via param, then remember it's name and location and save it there if the users pressing ctrl-s.
Thank you very much.
Posted by: pspad | Date: 2014-04-30 18:29 | IP: IP Logged
Download latest build from the PSPad developer forum. This functionality works correctly there
