You are here: PSPad forum > Bug report / Hlášení chyb > Code case change window
Posted by: francheu | Date: 2013-11-09 12:12 | IP: IP Logged
I'm not sure if it's a bug or a feature, but when you click OK the code case change window is not closed... (You have to click cancel to close it.)
Is it possible to add an "apply" button that changes the code case and let the window open, and close the window (after changing the code case) with the OK button ?
François
Posted by: pspad | Date: 2013-11-10 08:42 | IP: IP Logged
It's intentional. You see the changes after you make some changes immediately and you are able to make some changes step by step.
I agree, there is missing button Apply, to be correct. I will add it.
OK - make change and close window
Apply - make change without closing
Cancel - close window
Posted by: francheu | Date: 2013-11-10 13:37 | IP: IP Logged
pspad:OK - make change and close window
This is exactly what I expected.
Thanks in advance for implementing it
François
Posted by: pspad | Date: 2013-11-10 17:58 | IP: IP Logged
Already done. It will be available in the next build
Posted by: francheu | Date: 2013-11-11 16:01 | IP: IP Logged
Great, thanks !
François
