You are here: PSPad forum > Bug report / Hlášení chyb > Re: High resolution icon in Windows 7
#1 High resolution icon in Windows 7
Posted by: mgutt | Date: 2013-11-07 23:48 | IP: IP Logged
The resolution of the PSPad icon is very low. Maybe you can raise the resolution in a future release.
#2 Re: High resolution icon in Windows 7
Posted by: pspad | Date: 2013-11-08 04:54 | IP: IP Logged
Icon is in resolitions 16x16, 32x32 and 48x48, all in 256 colors. It isn't enough?
#3 Re: High resolution icon in Windows 7
Posted by: mgutt | Date: 2014-02-21 09:48 | IP: IP Logged
No. Look:
Ugly frame + low resolution
#4 Re: High resolution icon in Windows 7
Posted by: prema_van_smuuf | Date: 2014-02-22 02:36 | IP: IP Logged
It doesn't look THAT bad.. tongue sticking out smiley
#5 Re: High resolution icon in Windows 7
Posted by: carbonize | Date: 2014-02-23 14:38 | IP: IP Logged
People actually use large icons on the desktop sad smiley
Carbonize
#6 Re: High resolution icon in Windows 7
Posted by: pspad | Date: 2014-02-23 14:51 | IP: IP Logged
It's no problem to add higher resolutions too
#7 Re: High resolution icon in Windows 7
Posted by: pspad | Date: 2014-02-24 12:30 | IP: IP Logged
From the next build will be included bigger format of icons up to size 256x256
I found Window uses iconcache, so you can experience problems new icond wont be visible up to rebuild icon cache - delete file %userprofile%\AppData\Local\IconCache.db and reboot
#8 Re: High resolution icon in Windows 7
Posted by: carbonize | Date: 2014-03-01 21:33 | IP: IP Logged
Maybe time for a new icon as well. Going with the flat style that is all the rage now. I'm sure someone could knock one up for you.
Carbonize
#9 Re: High resolution icon in Windows 7
Posted by: aleskva | Date: 2014-03-29 16:54 | IP: IP Logged
PSPad icon made display as high-res by me:
sbirkaodkazu.8u.cz
And I think, that the right time for new flat icon might be after the PSPad redesign at some time in the future winking smiley
Edited 2 time(s). Last edit at 2014-03-29 16:54 by aleskva.
