You are here: PSPad forum > Bug report / Hlášení chyb > Re: DL, DT, DD tags are not highlighted
#1 DL, DT, DD tags are not highlighted
Posted by: fetis | Date: 2013-05-21 21:11 | IP: IP Logged
subj
pspad version is 4.5.8 (2455)
I use PSPad for HTML, JS editing.
#2 Re: DL, DT, DD tags are not highlighted
Posted by: Vany | Date: 2013-05-22 07:44 | IP: IP Logged
depends on hiliter - use XHTML (or HTML)
#3 Re: DL, DT, DD tags are not highlighted
Posted by: fetis | Date: 2013-05-23 11:43 | IP: IP Logged
Neither "HTML", nor "XML", nor "HTML Multi" doesn't work for me
#4 Re: DL, DT, DD tags are not highlighted
Posted by: pspad | Date: 2013-05-23 12:49 | IP: IP Logged
Wait for the next build. Only few pair tags is highlighted. I added DD, DT, DL
Edited 1 time(s). Last edit at 2013-05-23 12:49 by pspad.
#5 Re: DL, DT, DD tags are not highlighted
Posted by: fetis | Date: 2013-05-27 14:50 | IP: IP Logged
Thanks!
