You are here: PSPad forum > Bug report / Hlášení chyb > Re: Code Explorer don't show function of C++ with namespace
Posted by: sphaira | Date: 2013-05-21 20:36 | IP: IP Logged
I have tested the same cpp file with namespace bracket and without. The code Explorer don't show any Class, functions, define or types within a namespace. I can only show the include.
Example of namespace bracket with no explorer code :
namespace log{
#define MAXPRINTMSG 4096
void logger::Print( const char * msg){
OutputDebugString( msg );
} // end of namespace log
I found the solution. You just have to put bracket at the line after the namespace like this :
namespace log
{ // line after the namespace name ('log')
This is not really a serious bug but could you fix in a future release ?
Thanks.
Edited 5 time(s). Last edit at 2013-05-21 20:46 by sphaira.
Posted by: pspad | Date: 2013-05-23 13:33 | IP: IP Logged
Namespace parsing was fixed. I hope all will be ok. If there will be any problem, please send me source code causing it.
Fix will be available in the next build
