You are here: PSPad forum > Bug report / Hlášení chyb > Wrong size of horizontal scroller for long lines
#1 Wrong size of horizontal scroller for long lines
Posted by: xsirvent | Date: 01/04/2012 09:14 | IP: IP Logged
Hi everybody,
Since I use the last stable version (4.5.6 (2427)) I have a problem while editing some log files containing very long lines.
When I use the horizontal scroller to go to the end of a long line, the scroller hits the right border of the window before the end of the line. I have to click on the ">" icon to scroll the line one character by one.
I found a workaround : Edit the long line by adding or removing a character and the horizontal scroller will change to the right size and position for the whole document.
Does anyone have the same problem ?
#2 Re: Wrong size of horizontal scroller for long lines
Posted by: pspad | Date: 01/04/2012 09:52 | IP: IP Logged
Can you send a screenshot?
#3 Re: Wrong size of horizontal scroller for long lines
Posted by: khagaroth | Date: 01/07/2012 18:18 | IP: IP Logged
Confirmed. There won't be much to see on that screenshot. Basically, the scroll bar is at the end, but the line isn't, that's all.
