You are here: PSPad forum > Bug report / Hlášení chyb > Redraw problem after paste code
#1 Redraw problem after paste code
Posted by: ndt | Date: 03/06/2010 18:50 | IP: IP Logged
hi,
I found some bug with redrawing screen after some code is pasted to our file. I linked some small files you can reproduce that issue.
1. Open paste_me1.c, paste_me2 and copy_me.c files with PSPad.
2. Select all content of copy_me.c and copy it to clipboard
3. Paste code at 17 line in paste_me1.c - everything is okay
4. Paste code at 31 line in paste_me2.c - lines 31-34 wasn't redrawed (if you select that line everything will be fine)
regards,
Bartek
Download test_me.zip [842 bytes]
Edited 1 time(s). Last edit at 03/06/2010 18:50 by ndt.
#2 Re: Redraw problem after paste code
Posted by: pspad | Date: 03/14/2010 11:34 | IP: IP Logged
I tested is with the latest 4.5.5 build and don't see any redraw problems
Editor PSPad - freeware editor, © 2001 - 2015 Jan Fiala
