You are here: PSPad forum > Bug report / Hlášení chyb > Cannot save file from Shared Folder with VirtualBox
#1 Cannot save file from Shared Folder with VirtualBox
Posted by: Lolo | Date: 02/22/2010 13:36 | IP: IP Logged
It seems there is a problem with save functionality.
In a specific configuration, you cannot save your file.
It happens when you use PSPad from VirtualBox (under Windows XP) AND you modify a file from a VirtualBox Shared Folder.
I have the following error:
Error saving file "H:\test.txt"
Otherwise, it works very well if you save a file from any others folders.
More, if I switch from another application and return into PSPad, it tell me that file content has changed.
If I reload it (answer Yes), the content is corrupted.
For example, I have a simple file with the string AZERTY inside.
I open it with PSPad and add a second line. So I have
AZERTY
FOO
When I reload it, I have this:
For information, I am using the last beta v4.5.5 (2884)
I hope you could fix it in the next release.
Please, let me know if you need more informations.
Lolo.
Edited 1 time(s). Last edit at 02/22/2010 13:36 by Lolo.
#2 Re: Cannot save file from Shared Folder with VirtualBox
Posted by: pspad | Date: 02/26/2010 08:21 | IP: IP Logged
Tested with latest build on VirtualBox and shared folder.
I tested to save new file and open existing file from shared folder and save it.
Both file was possible to save.
Please tell me condition how to simulate it.
#3 Re: Cannot save file from Shared Folder with VirtualBox
Posted by: Lolo | Date: 02/26/2010 13:10 | IP: IP Logged
3.1.4r57640
Thanks for your response.
I will try to give you more informations.
In attachment, a screenshot of my Shared Folder configuration.
My virtual machine is under Windows XP SP3 (with all patch from Microsoft)
I have no antivirus and no firewall.
All my hard drive are in NTFS but without any particular right.
I simply edit any file from any folder on any shared folder.
And if I try to save it with PSPad I have the previous error message.
I have done some tests and it is particularly strange.
It only happen on Shared Folder (see screenshot in attachment)
If I create an empty file (from windows explorer), open it with PSPad, modify it and save it => it works
But, if I open again the same file, complete it and try to save it => I have the error message: Error saving file : I:\test.txt
I have the same behavior if a create a new file, modify it, save it one time and directly save it a second time.
And, more strange, if I edit the file in hexadecimal mode in order to modify it, I can save it.
I have try to map a network folder on my Shared Folder (in order to access it easily) but I have the same behavior.
I hope it could help you.
If you need more details, please let me know.
I can also make a video if you want.
Thanks.
#4 Re: Cannot save file from Shared Folder with VirtualBox
Posted by: pspad | Date: 02/26/2010 14:19 | IP: IP Logged
OK. I found a one thing. Is file is unicode/utf_8, you can save it. If file is in ANSI, you get error message.
I start to look for a problem.
#5 Re: Cannot save file from Shared Folder with VirtualBox
Posted by: Lolo | Date: 02/26/2010 16:16 | IP: IP Logged
You are right.
It is exactly that.
Save Unicode files work but ANSI failed.
I hope you will be able to fix it.
Thanks and have a nice day.
Lolo.
#6 Re: Cannot save file from Shared Folder with VirtualBox
Posted by: pspad | Date: 02/26/2010 17:21 | IP: IP Logged
I found and fix problem even I don't understand why it causes exception winking smiley
#7 Re: Cannot save file from Shared Folder with VirtualBox
Posted by: Lolo | Date: 03/01/2010 16:43 | IP: IP Logged
You have fix the problem with error only but if you reload your file, you will see that it is broken.
For example:
- Create a new file from Windows explorer (call it Test.txt)
- Now open it with Notepad and type any text (AZERTY for example)
- Now open it with PSPad and add text at the end of the file and save it.
Now, press Ctrl + R => you can see that the file is broken
See screenshot:
