You are here: PSPad forum > Bug report / Hlášení chyb > Re: PHP Compiler
Re: PHP Compiler
#1 PHP Compiler
Posted by: fdimeo | Date: 02/07/2010 16:46 | IP: IP Logged
Hi dears,
I noticed that using:
Windows 7 Professional
PSPad 4.5.4 (2356)
CTRL+F9 doesn't work and either isn't possibile to compile while there are 2 or more PHP files opened.
Using the same configuration, same number of PHP opened files under Windows XP Profesional compiler works fine.
Fabrizio
#2 Re: PHP Compiler
Posted by: pspad | Date: 02/07/2010 17:23 | IP: IP Logged
In my opinion it doesn't depends of number of open files.
PSpad sends to compiler main project file if assigned or current file.
On Windows 7 can be a problem with user rights
#3 Re: PHP Compiler
Posted by: carbonize | Date: 02/07/2010 22:03 | IP: IP Logged
Worked fine here with five PHP files open. Needed to save the file first of course.
Carbonize
Editor PSPad - freeware editor, © 2001 - 2015 Jan Fiala
