You are here: PSPad forum > Bug report / Hlášení chyb > include detection
include detection
#1 include detection
Posted by: CravenA | Date: 11/05/2009 16:59 | IP: IP Logged
I think it's a bug, but not quite sure. Maybe it's up to me to change my coding behaviour.
If you look at the PHP code below, you will see file included via the include(); function, but if you paste this in the editor and open up the 'Code explorator', (Shift+Ctrl+E), be sure to refresh, you will only see that 2 files are included in the file.
<?php
include 'test1.inc';
print("hi"); include 'test2.inc'; print("there");
include 'test3.inc';
The difference is that 'test2.inc' is included AFTER a print(); statement. If it's like this, it's ok;
<?php
print("hi");
So I presume that the include detection only works if the include(); function is the first thing on the line.
To include something in the middle of a print statement is great for not making too much lines, like this;
print("
<table>
<tr>
<td>"); include 'tablecontent.inc'; print("</td>
</tr>
</table>
instead of making this;
print("
<table>
<tr>
<td>");
print("</td>
</tr>
</table>
That's just a short example.
Thanks, keep up the great ... GREAT work !
#2 Re: include detection
Posted by: carbonize | Date: 11/05/2009 20:19 | IP: IP Logged
I'd say it's a bug although your style is a little unorthodox and would make reading your code later a lot harder. PSPad is obviously just looking for the first item on each line rather than looking for where that line of code is ended with a ; and looking at what comes next.
Carbonize
