You are here: PSPad forum > Bug report / Hlášení chyb > Automatic horizontal scrolling while using "Soft wrap"
#1 Automatic horizontal scrolling while using "Soft wrap"
Posted by: banoslo | Date: 10/14/2009 20:51 | IP: IP Logged
something goes wrong when PSPad scrolls (horizontal) automatically editor content while using "Soft wraps".
For an example use softwrap at 40 characters.
Everything is fine when the PSPad window width is wide.
Now, try this: Resize to a very small window width.
And now, insert text by typing keys. The effect is curious, PSPad scrolling does not work appropriately.
Best regards,
#2 Re: Automatic horizontal scrolling while using "Soft wrap"
Posted by: pspad | Date: 10/15/2009 06:05 | IP: IP Logged
You cat set 2 modes of soft wordwrap in PSPad (Program settings). One is wrap with right edge, second is with window width.
Maybe second mode will fits you better.
