You are here: PSPad forum > Bug report / Hlášení chyb > bug in new file save
Goto Page: Previous1 2 3 Next
#11 Re: bug in new file save
Posted by: mfedder | Date: 09/27/2009 21:26 | IP: IP Logged
carbonize:
No I cannot replicate this neither but is he on Windows 7 or on 2003 ?
Carbonize, my co-worker uses WinXP Pro sp3 on his desktop. We share the same server, Win2003. I use Windows 7 on my laptop and can reproduce the "Reload" problem at will.
If others see the problem only with Windows 7, the question is: How/when does Windows 7 commit a file to disk and mark the file as modified? When saving via PSPad, does Windows immediately flush the write buffer or is it flushed when the browser requests the newly saved file? The "Reload" problem might be explained if the latter is true.
Edited 1 time(s). Last edit at 09/27/2009 21:36 by mfedder.
#12 Re: bug in new file save
Posted by: carbonize | Date: 09/29/2009 05:51 | IP: IP Logged
I am on Windows 7 and cannot replicate this bug.
Carbonize
#13 Re: bug in new file save
Posted by: mfedder | Date: 09/29/2009 14:32 | IP: IP Logged
That's interesting. There's one aspect I haven't tested... I'm on a laptop and use offline file synchronization to take a copy of my network files with me. Perhaps the sync process is causing the problem.
I'll do a little more testing to see if I can isolate and confirm my theory.
#14 Re: bug in new file save
Posted by: mattb | Date: 11/12/2009 12:50 | IP: IP Logged
I have exactly this problem also with Win 7. I have a multi monitor environment.
#15 Re: bug in new file save
Posted by: pspad | Date: 11/12/2009 13:38 | IP: IP Logged
mattb:
Did you use 4.5.5. build from PSPad developer forum? New file bug should be fixed
#16 Re: bug in new file save
Posted by: cusimar9 | Date: 11/23/2009 19:35 | IP: IP Logged
I am also experiencing this bug. This is using v4.5.4(2356)
I have two machines with Windows 7 Ultimate, one is a desktop and one is a laptop.
They are on a Homegroup. The laptop connects to the Desktop Homegroup.
When I edit a file in PSPad on the laptop, if PSPad loses focus and then regains focus, I am told that the file contents have changed.
This happens every time without fail, but seems to take around 10 seconds after the file has been saved before it alerts me.
The time on both machines has been synchronized.
I never had this problem until I moved to Windows 7.
I would be very grateful if a fix to this could be found and I am happy to test further.
In the meantime can the alert be disabled?
#17 Re: bug in new file save
Posted by: pspad | Date: 11/23/2009 19:48 | IP: IP Logged
cusimar9:
Program settings / Direct edit
CheckDocChanges=0
#18 Re: bug in new file save
Posted by: cusimar9 | Date: 11/24/2009 00:05 | IP: IP Logged
cusimar9:
CheckDocChanges=0
Thanks!
#19 Re: bug in new file save
Posted by: dozern | Date: 12/09/2009 19:15 | IP: IP Logged
First of all, congratulations for PSPad, it is a great software. grinning smiley
I also encounter this "reload?" problem since I upgraded to win 7.
Before that, I was using win XP and all works fine (PSPad 4.5.4.2356)
I have just tried to upgrade to PSPad 4.5.5 beta 2374 and that doesn't fix it.
May be the problem is related to network drives, because when I save a file on my local computer, I can't reproduce the bug.
The server is under win 2k3 and it is in the same domain that my desktop computer.
The clocks of the server and the local computer seems to be synchronized.
I access the network share through a mapped network drive.
I haven't tried UNC path yet.
#20 Re: bug in new file save
Posted by: Lolo | Date: 01/05/2010 12:49 | IP: IP Logged
I have exactly the same problem than dozern (with v4.5.5 build 2374).
It seems that PSPad does not detect when files are modified on network folder.
It is particularly annoying when working with several users on same files because PSPad does not prevent that file has been modified.
I hope it could be fixed in a future release.
Thanks and have a nice day.
