You are here: PSPad forum > Bug report / Hlášení chyb > Shifting
Shifting
#1 Shifting
Posted by: Skulstad | Date: 03/18/2009 09:56 | IP: IP Logged
Hi.
When typing '(' etc. (--> 'Completion of chars'), it all works ok when in insert mode, ie. 2 chars are inserted and the rest of the line is shifted 2 places to the right. When in overwrite mode, 2 chars are inserted (correct) and the rest of the line is shifted 1 place to the right. This happens even if ther are "sufficient" blank chars in a line. Should this be fixed (no shift in overwrite mode)?
This case applies at least to .txt.-documents.
Build 2346.
Regards,
Jorn Chr. Skulstad
#2 Re: Shifting
Posted by: Skulstad | Date: 04/14/2009 08:46 | IP: IP Logged
One more comment on this issue: when undoing, the text gets a little messed up, ie. some chars are not reset, are reset wrong, or are simply missing/disappearing.
Regards,
Jorn Chr. Skulstad
#3 Re: Shifting
Posted by: Skulstad | Date: 07/06/2009 09:47 | IP: IP Logged
This issue seems to have been fixed. Excellent!!
Regards,
Jorn Chr. Skulstad
