You are here: PSPad forum > Bug report / Hlášení chyb > opening web links
opening web links
#1 opening web links
Posted by: caccamo88 | Date: 11/19/2008 15:13 | IP: IP Logged
I notice opening web-links (saved in a .txt and opened with pspad) with Ctrl+mouse_click (on the link) is successful ONLY if there is ONE tab opened.
If I open more tabs (contains document in general not specific document with links), Ctrl+Ctrl+mouse_click (on the link) dosn't play anymore.
Doesn't play even if I close all tabs (except the one in which I have web links).
The solution is to close and open PSPad again, any hint?
#2 Re: opening web links
Posted by: pspad | Date: 11/19/2008 18:23 | IP: IP Logged
Do you use the 4.5.4 PSPad version?
#3 Re: opening web links
Posted by: caccamo88 | Date: 11/20/2008 18:11 | IP: IP Logged
Fantastic, bug is corrected in 4.5.4. Now it's possible to open link even in more tabs, thanks!
