You are here: PSPad forum > Bug report / Hlášení chyb > [BUG] Non-greedy regexp is greedy
Posted by: SanskritFritz | Date: 11/12/2008 16:04 | IP: IP Logged
This is the search expression:
This is where i preform the search:
CC-3623843-4/2008
I expected PSPAd to find
-4/
but it only finds
-3623843-4/
Edited 1 time(s). Last edit at 11/12/2008 16:05 by SanskritFritz.
Posted by: vbr | Date: 11/12/2008 16:59 | IP: IP Logged
SanskritFritz:This is the search expression:-.*?/
This is where i preform the search:CC-3623843-4/2008
I expected PSPAd to find-4/
but it only finds-3623843-4/
I belive, this is a standard behaviour, which you also get in other re engines (I just checked python and javascript). The search is performed left-to-right, the backtracking is only used if there is no match reached.
Can you maybe provide a sample of data and what should be matched? (maybe the pattern could be adopted).
You can e.g. use the following to get the wanted effect:
or some other pattern.
