You are here: PSPad forum > Bug report / Hlášení chyb > Mass replacement don't work
Posted by: poncho | Date: 04/01/2008 10:24 | IP: IP Logged
I tried to replace "\r\n" in a large string with a real new line. I used regex, search="\\r\\n", replace="\n".
PSPad replaces only the first match.
I used a constans field from a Typo3 template (over 4800 chars in a single line)
PSPad 4.5.4 (2308)
Posted by: vbr | Date: 04/01/2008 10:42 | IP: IP Logged
poncho:I tried to replace "\r\n" in a large string with a real new line. I used regex, search="\\r\\n", replace="\n".
Hi, due to the current limitation of the regex engine the backward search should be used for replacements with newlines.
See e.g. forum.pspad.com
Edited 1 time(s). Last edit at 04/04/2008 20:48 by Stefan.
