You are here: PSPad forum > Bug report / Hlášení chyb > Freeze exploring after disconnection [all versions]
#1 Freeze exploring after disconnection [all versions]
Posted by: xml | Date: 03/11/2008 02:21 | IP: IP Logged
Stable bug in all versions: after a session working on a LAN, if you disconnect or change LAN, everytime you make an action using explorer (open..., text differences, find in files...) PSPAD freezes while opening last current position and there is no way to kill it (close, task manager etc...). Sometime freeze ends after many minutes: perhaps longer timeout?
Thanks for this great tool
Enrico
#2 Re: Freeze exploring after disconnection [all versions]
Posted by: pspad | Date: 03/11/2008 06:17 | IP: IP Logged
This is a problem of the operating system, not a programs problem.
Windows try connect your mapped disks.
#3 Re: Freeze exploring after disconnection [all versions]
Posted by: xml | Date: 03/11/2008 09:53 | IP: IP Logged
You're right, but I'm not using logical disks, but phisical addresses (\\192.168...), and I experienced this in many situations in the last 4 years. I think it's common to work in this way. Could you operate on any timeout or similar calling Win explorer library to avoid freezing?
All my respects, I apologize for disturbing, thanks for the software and your attention in this forum.
Enrico
#4 Re: Freeze exploring after disconnection [all versions]
Posted by: pspad | Date: 03/11/2008 10:32 | IP: IP Logged
PSPad hasn't any own timeout. I am using tandard system file access
