You are here: PSPad forum > Bug report / Hlášení chyb > PS Pad report for TEXT diff
Posted by: anita | Date: 01/31/2008 07:24 | IP: IP Logged
Hi There,
Please share your views about generating reports in PS-Pad for Text Diff, I understand that we can generate the simple report for missing lines et.al.
But my purpose is to compare two (HTML/TXT) file and generate an excel sheet with both file differences /discrepancies in separate columns, is it possible....if yes pls do enrich me with ur exp
Rgds
Anita
Posted by: MrSpock | Date: 01/31/2008 11:40 | IP: IP Logged
I'm not saying PSPad's text diff isn't good, but maybe a dedicated comparison tool like WinMerge is better suited for this kind of job. It can generate patch files, and if you could find some way to convert these to csv, you'd be done.
BTW why are you posting this in the bug report section?
Edited 1 time(s). Last edit at 01/31/2008 11:41 by MrSpock.
