You are here: PSPad forum > Bug report / Hlášení chyb > Administrator rights needed for install
#1 Administrator rights needed for install
Posted by: Orlando | Date: 12/08/2007 17:59 | IP: IP Logged
pspad453inst_en.exe
Win2000 Sp4
Installation of PSPad 4.5.3 not possible. Installation program stops with MessageBox: "You must be logged in as an administrator when installing this program."
#2 Re: Administrator rights needed for install
Posted by: vbr | Date: 12/08/2007 19:18 | IP: IP Logged
In such a case you can download the CAB archive and unpack it to the desired location (however, one must unpack it preserving the directory structure with subdirectories!). PSPad itself doesn't require the installation; the shortcuts could be created manually.
#3 Re: Administrator rights needed for install
Posted by: Orlando | Date: 12/08/2007 21:21 | IP: IP Logged
vbr:
Thanks, I know and use the workaround with the cab Archive. But Admin rights are not necessary for PSPad install. Besides, the context menu entries are not available with a 'cab installation'.
#4 Re: Administrator rights needed for install
Posted by: pspad | Date: 12/08/2007 23:26 | IP: IP Logged
Admin rights are necessary, if you want to register PSPad shell extension.
