You are here: PSPad forum > Bug report / Hlášení chyb > text wrapping doesn't works correct in 2275
Posted by: Bobf | Date: 09/20/2007 09:08 | IP: IP Logged
Hello Jan,
i'm using since a long time your great PSpad, but with the last few betas i'm a little bit unsatisfied.
because i use the PSpad also from some TXT files. so when i instert a text or write a text the text would be wrapped in the right mark (as defined in the settings).
After wrapping, the text starts at the next line with a space. You can see this, when you enable show/hide space...
I know there was a problem in a older build and was fixed in 2265... but now the problem reoccurs.
So please explain me, why is this changed and is there a way to fix this again.
I have already sent two screenshots to you, where you can see what i mean.
with build 2275 the new line will begin always with a space. This is wrong ?
Other editors like notepad++, textpad, or UltraEdit doesn't show this behavior.
Please fix this !!!
many thanks Bob
Posted by: titi4u | Date: 09/24/2007 17:19 | IP: IP Logged
yes for me too text wrapping doesn't work very well.
I've already sent a reply about text wrapping ("Search not wrapping to top of the file", forum.pspad.com), but the bug correction was clumsy. I wonder if it will ever work correctly, each time there is another problem in this area ...
For example using now F3 combined to shift+ctrl+up/down : 1) Pspad misses sometimes one match in the file
2) F3 is case-sensitive, but shift+ctrl+up/down is not (but in older versions it was ! And so it should be again)
Please, please, please, could you spend some time to correct text wrapping + search shortcuts once for all !
It's something that is very useful and important on all text editors, don't neglect it !
Thanx a lot,
and sorry to annoy you with that,
Thierry.
Posted by: Bobf | Date: 10/01/2007 13:16 | IP: IP Logged
Hello Thierry,
it seems we are the only one with this problem.
Also the latest build 2280 has still this problem.
I have sent Jan a mail, but without response.
I still hope for a fixed build soon.
Bob
Posted by: pspad | Date: 10/01/2007 13:53 | IP: IP Logged
Jan has a too much work to be able develop and repond all mails
I'v got over 50 PSPad related mails per day.
Posted by: titi4u | Date: 10/01/2007 14:25 | IP: IP Logged
Hi Bob,
yes i hope too to have a fixed build soon.
For the moment, I'm stuck with version 4.5.2 build 2237,
which is quite an old one, but works good
And I'm "happy" to see i'm not alone to have this problem, it's reassuring
Posted by: pepperpod | Date: 10/07/2007 19:45 | IP: IP Logged
I expect this is a related problem but sometimes a punctuation mark will wrap to the next line.
Posted by: Bobf | Date: 10/18/2007 20:14 | IP: IP Logged
Hello Jan,
i new build is out now (2282) but the problem is still there. There are a lot of bug fixes, and when will be this bug fixed ??
I think this could not be a big problem.
I hope very soon for a solution.
rgs Bob
Posted by: Bobf | Date: 10/26/2007 14:07 | IP: IP Logged
Hello Jan,
today the build 2283 is out. But the old problem still exists. Please fix old bugs before add some new features.
When did you fix finally this bug ?
Is this to diffcult ?
many thanks Bob
Posted by: pspad | Date: 10/26/2007 14:54 | IP: IP Logged
Yes, it's dificult.
As you see, I don't add new featuresm, but I am correcting problems
Posted by: Bobf | Date: 10/26/2007 16:59 | IP: IP Logged
Jan,
many thanks for the quick response, but as i know we had the same or similar problem in the past and was fixed in 2265. So is the new problem different from old one ?
From the build 2265
" WordWrap with right edge mark was limited to 256. There is a problem with cursor for higher values yet. ""
I still have the hope for a fix asap.
many thanks Bob
