You are here: PSPad forum > Bug report / Hlášení chyb > Crash on multiple file load
Posted by: louisrowdy | Date: 08/09/2005 06:24 | IP: IP Logged
I'm working on an XP SP2 domained workstation using 4.3.3. If PSPad is not loaded and I try to select more than one file (generic text files of varying suffix names) from Windows Explorer it will crash almost every time. However if I've loaded PSPad with a single file and then load multiple files the problem disappears.
Posted by: pspad | Date: 08/09/2005 06:36 | IP: IP Logged
Do you have last build 4.3.3 (2092) ?
Can you try it with last 4.5.0 beta (available in beta forum) ?
Posted by: Luciano | Date: 08/11/2005 16:03 | IP: IP Logged
Hi All,
same error using the following steps: select multiple files (52) from the dir, all with the same extension and press enter.
Error reading TextLabel.Lines.Strings: System Error. Code: 1400.
Invalid window handle.
Exception class: EReadError
Exception address: 00427B87
Stack list, generated 8/11/2005 4:01:18 PM
[00411BED] SysUtils.RaiseLastOSError + $75
[00404DB6] System.@HandleFinally + $2A
[004A2DE8] Controls.TWinControl.CreateWnd + $130
[0045E106] ComCtrls.TCustomTreeView.CreateWnd + $16
[004A31B6] Controls.TWinControl.CreateHandle + $16
[004A5D30] Controls.TWinControl.HandleNeeded + $1C
[004A5D3D] Controls.TWinControl.GetHandle + $5
[0045D42B] ComCtrls.TTreeNodes.GetHandle + $3
[0045D990] ComCtrls.TTreeNodes.SetUpdateState + $14
[0045D971] ComCtrls.TTreeNodes.BeginUpdate + $D
[005A4736] uLinks.TfLinks.LinksLoadFromFile (Line 322, "uLinks.pas" + 32) + $F
LAST WARNING !
LOG result don't send to forum !
