You are here: PSPad forum > Bug report / Hlášení chyb > Access violation on "Results of LIST Command"
Posted by: mydna | Date: 2017-10-14 08:23 | IP: IP Logged
Exception description:
To produce this Access Violation right click on the active window of any open text file and click on "Show / Hide LOG Window" at the bottom of the context menu. Click on the "ftp" tab on the far right of the bottom of the window that opens. Then click the first icon at the top of the left side labeled "Results of LIST Command" when you mouse over the icon. That's when the Access Violation happens. This is reproducible running pspad.exe v5.0.0 (243).
Access violation at address in module '.exe'. Read of
address .
Exception class:
Exception address:
Stack list, generated 14/Oct/17 4:02:20 AM
(See forum.pspad.com)
Also please describe most exact what you have done
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thanks
INFO
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.0 (243)
System : Windows 10 Home Edition x64, Version: 10.0, Build: 3AD7,
Processor: Intel, Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz, 2400 MHz MMX
Display : 1366x768 pixels, 32 bpp
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit "_4"
Edited 1 time(s). Last edit at 2017-10-30 13:23 by Stefan.
Posted by: Gorlash | Date: 2017-10-30 03:59 | IP: IP Logged
Damn... I keep hoping he'll finally get this crash fixed; it's been the curse of my years of intermittent experience with PsPad; I really cannot use an editor on the job, when it regularly crashes on me... what a pain.
I'll try again in a few months.
