You are here: PSPad forum > Bug report / Hlášení chyb > Multiple file opening
#1 Multiple file opening
Posted by: carbonize | Date: 2013-05-19 14:34 | IP: IP Logged
If you select multiple files then select PSPad from the systems context menu it is not opening all the selected files. The amount of files it opens changes each time. I just selected six files and used context menu and it opened four files. I closed PSPad and used context menu again and this time it only opened one file?
Carbonize
#2 Re: Multiple file opening
Posted by: carbonize | Date: 2013-05-19 14:40 | IP: IP Logged
Just to add I am using a portable version and not an installed version.
Carbonize
#3 Re: Multiple file opening
Posted by: Jeepo | Date: 2017-07-03 23:19 | IP: IP Logged
When I try to open multiple files (about 30) I get a message: The exception unknown software exception (0xeedfade) occured in the application at location 0x7c812aeb. Windows XP SP3 32-bit.
#4 Re: Multiple file opening
Posted by: pspad | Date: 2017-07-04 07:14 | IP: IP Logged
Jeepo:
What PSPad version do you use?
How is PSPad intergrated into explorer? Registry od DLL library (Program settings / System integration)? I suggest you to set DLL library.
