You are here: PSPad forum > Bug report / Hlášení chyb > build 2743 - bug in multi-line tabs
Posted by: Gorlash | Date: 2017-01-26 22:19 | IP: IP Logged
I have a new bug in build 2743; when I open multiple tabs, the lower row of tabs is over-written by the top of the text window.
I tried closing/re-opening the editor, that had no effect.
The effect can be seen in this image:
www.flickr.com
Posted by: betadex | Date: 2017-05-25 07:57 | IP: IP Logged
I can see the same problem. It occurs on the 5th line of tabs. 4 lines of file tabs look fine, but when I open more tabs to fit to 5th line, they are partially hidden, like they are positioned behind the main editor window.
Posted by: pspad | Date: 2017-05-25 08:16 | IP: IP Logged
DOwnload current build of PSPad 5 from PSPad developer forum.
This problem is fixed already
Posted by: betadex | Date: 2017-05-25 12:19 | IP: IP Logged
I downloaded the most recent build and the bug is still there. It happens when I choose:
File Tabs Style: "Flat buttons" or "Buttons".
If I use "Tabs" option, it works fine.
Posted by: pspad | Date: 2017-05-25 12:30 | IP: IP Logged
Can you send me screenshot?
I need to know your OS version and you screen DPI - e,g, if you changed size of font in windows screen settings
