You are here: PSPad forum > Bug report / Hlášení chyb > Key map
Key map
#1 Key map
Posted by: Anonymous User | Date: 2017-03-22 11:31 | IP: IP Logged
Win7Pro/PsPad 5.0.0(136)
Hi. When standing on the last item in Program Settings (Key Map) and press Direct Edit, nothing happens (except an empty box). In addition, for some reason, sometimes PsPad freezes; I was not able to reproduce this, though.
#2 Re: Key map
Posted by: pspad | Date: 2017-03-22 16:09 | IP: IP Logged
Tested it now and I wasn't able to simulate it
#3 Re: Key map
Posted by: vbr | Date: 2017-03-22 20:06 | IP: IP Logged
Hi, I can confirm the mentioned bug with Direct edit
If I open Settings: Program settings...
and activate the last pane:
Key Map,
after clicking on [Direct edit] button, only an empty window for this settings is displayed
This doesn't happen after clicking on "Direct edit" from other positions (i.e. when other items of settings are activated) - the normal content of special settings is displyed as expected.
However, I am fortunately not experiencing freezes or crashes od PSPad in such situation.
(Using PSPad 5, 136, Win7)
regards,
#4 Re: Key map
Posted by: pspad | Date: 2017-03-22 21:04 | IP: IP Logged
Found it. It will happen in case when there was no shortcut changed - keymap.ini doesn't exists.
This behavior is there from the begin, old version will behave same way. I will fix it.
