You are here: PSPad forum > Bug report / Hlášení chyb > HTML/multihightlighter problem
#1 HTML/multihightlighter problem
Posted by: jma | Date: 2013-04-19 10:55 | IP: IP Logged
I have a php file quite large, include.php, 247k.
When I load it the HTML highlighter loads, all other php files loads with the HTML multihighlighter. This means the Code Explorer window does not populate so I have to 1.change highlighter, refresh and sort Code Explorer each time I open this file.
Strange thing is that this file does not have any HTML, its just lots of php functions and defines.
First lines in the file are:
<?php
// include.php - PM
/Martin
#2 Re: HTML/multihightlighter problem
Posted by: pspad | Date: 2013-04-19 11:32 | IP: IP Logged
Program settings / Direct edit button
Change value of variable:
MultiHLOnUpToSize=500000
#3 Re: HTML/multihightlighter problem
Posted by: jma | Date: 2013-04-19 21:21 | IP: IP Logged
Great!
Helps with the highlighter but the Code Explorer window still does
not autofill.
Found it, CodeExplorerLimit=
BIG thanks!
/Martin
