You are here: PSPad forum > English discussion forum > Re: Clips for .md Markdown file do not work with hotkeys
#1 Clips for .md Markdown file do not work with hotkeys
Posted by: therium | Date: 06/30/2018 19:13 | IP: IP Logged
Windows 7
PSPad 5.0.0 (271)
I have created a "markdown (muti).def" file via Settings, Edit Clip Definition file, which contains this:
; PSPad clip definition file for Markdown (Multi)
; author: Chaz
; last revision 24. Jun 2018 09:46
[ftntref|footnote ref]*CTRL+ALT+Q
[HTMLcomment|HTML comment]*CTRL+ALT+P
In general, I want to surround selected text with some other stuff. One is hotkey combination is to put HTML comments around selected text. This is mapped to CTRL+ALT+P. However when I hit CTRL+ALT+P, nothing happens.
I have even restarted PSPad to see if it could pick up the changes but I can't get my custom key combinations to work.
How do I get this to work with .md files I'm editing?
Thank you.
Edited 1 time(s). Last edit at 06/30/2018 19:16 by therium.
#2 Re: Clips for .md Markdown file do not work with hotkeys
Posted by: Andreas | Date: 07/01/2018 18:38 | IP: IP Logged
Square bracket is not allowed: gogogadgetscott.info
Quote:
Note: You cannot have a line in your clip content that starts with the open square bracket, [ character as this marks the beginning of the next clip definition.
Also you have to use a space between alias and the description
[name |x description]*shortcut
