You are here: PSPad forum > English discussion forum > Regex issue (percentages)
Goto Page: Previous1 2 3 Next
#11 Re: Regex issue (percentages)
Posted by: maki | Date: 06/29/2018 08:06 | IP: IP Logged
All regex not work !!!
Info
Next occurrence of "[^\d\.]\d{1,2}(\.\d%|%)" not found.
OK
#12 Re: Regex issue (percentages)
Posted by: pspad | Date: 06/29/2018 08:24 | IP: IP Logged
You have square brackets in first part, why? Maybe it's time to read something about regular expressions.
Use this:
\s\d{1,2}(\.\d{1,2}%|%)
Edited 1 time(s). Last edit at 06/29/2018 08:26 by pspad.
#13 Re: Regex issue (percentages)
Posted by: maki | Date: 06/29/2018 14:48 | IP: IP Logged
#14 Re: Regex issue (percentages)
Posted by: vbr | Date: 06/29/2018 15:48 | IP: IP Logged
the regex search fails as expected on the given text
the starting part:
[^\d\.]
requires exactly one character other than a digit or a dot, which are not there at the given positions.
Using regex search for this might be rather demanding to get right;
if your log data for downloads are always on single line and you want to filter lines for incomplete downloads, it might be possible without regex in pspad.
in the Find dialog (Ctrl+F) use the pattern
100%
check [x] Copy non-matching
and click [Copy]
The resulting lines (other than those containing 100%) are then copied to a new file.
If there are other irrelevant lines in your data file, you can list only those containing "%"
again, use % in the search field,
uncheck [x] Copy non-matching
and click [Copy].
hth,
Edited 1 time(s). Last edit at 06/29/2018 15:49 by vbr.
#15 Re: Regex issue (percentages)
Posted by: aGerman | Date: 06/29/2018 16:31 | IP: IP Logged
The lines in #6 clearly show the percentages at the end of the line. Now the requirements changed and as Jan already said also the beginning of a line has to be matched as alternative and using OR in case the percentage is at the beginning of the line.
(^|[^\.\d])\d{1,2}(\.\d%|%)
Steffen
#16 Re: Regex issue (percentages)
Posted by: pspad | Date: 06/29/2018 17:26 | IP: IP Logged
maki:
I provided you working expression for your purposes in my latest answer.
You have no intention to learn, you have no intention to read answers.
Edited 1 time(s). Last edit at 06/29/2018 17:27 by pspad.
#17 Re: Regex issue (percentages)
Posted by: Andreas | Date: 06/30/2018 11:14 | IP: IP Logged
@maki
First try on this page before asking: regex101.com
^\d*\.?\d*%
#18 Re: Regex issue (percentages)
Posted by: maki | Date: 07/05/2018 13:08 | IP: IP Logged
I tested and found only percentages, not the full name with percentages. Regex can be compliced for 10000000 of different path... so it does not work correctly.
#19 Re: Regex issue (percentages)
Posted by: aGerman | Date: 07/05/2018 18:04 | IP: IP Logged
maki:
No, that's exactly what Regex is made for. You just have to specify the rules and that's it. The right pattern will work for 10 lines as good as for 10000000 lines.
(^|(^.*[^\.\d]+))\d{1,2}(\.\d%|%)
Steffen
#20 Re: Regex issue (percentages)
Posted by: maki | Date: 07/06/2018 09:53 | IP: IP Logged
aGerman:
maki:
Steffen
Work smiling smiley
R:\Gym\-5076373\-13974757_348284311.jpg -> I:\Gym\-5076373\-13974757_348284311.jpg - Kopiowanie zakończone powodzeniem 100%
R:\Gym\-5076373\-13974757_392683937.jpg -> I:\Gym\-5076373\-13974757_392683937.jpg - Kopiowanie zakończone powodzeniem 99.9%
