You are here: PSPad forum > English discussion forum > Re: How do delete HTML code in 100,000 HTML files at the same time?
Posted by: maki | Date: 2018-06-04 11:35 | IP: IP Logged
How do delete HTML code in 100,000 HTML files at the same time? (all tabs)
Edited 1 time(s). Last edit at 2018-06-04 11:36 by maki.
Posted by: pspad | Date: 2018-06-04 11:57 | IP: IP Logged
Use PSPad scripting
Use PSpad find/replace in files, if possible - no support for regular expressions, but it's really fast
Use specialised tool
Posted by: maki | Date: 2018-06-04 14:43 | IP: IP Logged
Give me a script and explain step by step.
Posted by: maki | Date: 2018-06-04 15:02 | IP: IP Logged
I tried the best of the best tools, but every tool damages charset! So I'm asking here, because every tool will damage Polish letters.
WTF??? ==> się dzieje co chce’
Even if the tool supports Unicode it will still damage the Polish letters, so I am looking for a tool that actually supports any language.
You can try with a million different fonts, you lose time, but if the coding is mixed, it will not display any coding correctly.
Edited 3 time(s). Last edit at 2018-06-04 15:08 by maki.
Posted by: pspad | Date: 2018-06-04 15:57 | IP: IP Logged
Can you provide any example first what do you want to replace?
Posted by: maki | Date: 2018-06-04 16:02 | IP: IP Logged
I want to remove the HTML code, but the editor can remove only one tab, and I want to remove the code in all open tabs.
Need option:
Apply to all open documents (all tabs)
Posted by: therium | Date: 2018-06-25 16:55 | IP: IP Logged
Is it even possible to have 100,000 files open in PSPad?
Try GrepWin. Requires Windows 7 SP1 or later.
It appears it can process all files in a directory. Check docs carefully for how it can process Polish characters. But in Perl, this is your regexp to use on each line of every HTML file:
$s=~s/<.+?>//g;
Posted by: maki | Date: 2018-07-05 13:15 | IP: IP Logged
It seems to be a complicated task, so I do not know what's going on.
I want the software to support millions of Unicode and all special characters, and all existing fonts in the world: D
Posted by: maki | Date: 2018-07-06 06:50 | IP: IP Logged
Works, thanks for help.
Posted by: syntech | Date: 2018-07-11 07:46 | IP: IP Logged
For search and replace tasks over (many) files/folder I highly recommend PowerGrep (https://www.powergrep.com/). It has it's price, but it's worth every penny. I use it every day at work.
