You are here: PSPad forum > English discussion forum > Hex View Find crashes
Posted by: zforray | Date: 2018-05-17 17:45 | IP: IP Logged
v500.277 (was 275 and upgraded but still crashes.
I create a new text document (ctrl-n) and paste some text I want to see if it contains some hidden hex characters.
I switch to "Hex View" and do a ctrl-f to find a string - "as text" is checked. As soon as I hit enter, it crashes:
Exception description:
Exception address:
Stack list, generated 5/17/2018 1:39:30 PM
(See forum.pspad.com)
INFO
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thank you very much!
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.0 (277)
System : Windows 7 Professional x64, Version: 6.1, Build: 1DB1, Service Pack 1
Processor: Intel, Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz, 3590 MHz MMX
Display : 1920x1080 pixels, 32 bpp
Active Controls Hierarchy:
TMaskEdit ""
TGroupBox ""
TfFindHex ""
The text I am pasting and searching is below. I am searching for the string "MUNKI"
12:58:42 PM WIND : q nodegroup f=d
Node Group Name: ADMINSYS
Node Group Description:
Last Update by (administrator): S2EABENN
Last Update Date/Time: 05/17/2018 12:10:18
Node Group Member(s): SOMADFS2-VM LISTS.VCU.EDU AIM101
EMPANDA-TEST.ADM.VCU.EDU SCRUFFY
EMPANDA.ADM.VCU.EDU SOMCAREWARE SOMRS2
SOMTRAUMABASE SOMEXAM BABBAGE.ADM.VCU.EDU AV1
AV2 AV3 AV4 TS-ASSETS TS-LABSTATS-PROD
EVENTS2HVAC PENTANAPROD PENTANATEST APP2GO6
APP2GO7 APP2GO8 APP2GO9 STOREFRONT1
STOREFRONT2 APP2GOLICENSE UCC-TELE-BACKUP
FILELOCKER.VCU.EDU LIST2.VCU.EDU
FILEDUMP.UCC.VCU.EDU NETMONP.CNS.VCU.EDU
NETMONH.CNS.VCU.EDU SOMCAREWARE2 SOMNDSR
BLOGSDB.VCU.EDU IMAGENOWDR IMAGENOWPROD
AIM-APP AIM-IQ VCUVSTSS1
TELE-WFO-KEY.RAMS.ADP.VCU.EDU VCUVSTSS
TELE-WFO-RECORD.VCU.EDU EXPERIENCE1 CA-OCSP
RVFUSIONNEW RVFUSIONNEW2 CA-AUTHDIR
ZURI.VCU.EDU PCPRODFAX VCUSPACETEST PCTESTFAX
LDAP1.VCU.EDU LDAP2.VCU.EDU LDAP3.VCU.EDU
LDAP5.VCU.EDU LDAP6.VCU.EDU DUO-PROXY
DUO-PROXY2 TUTORTRAC DDPE-CONSOLE DDPE-POLICY
ALC-WEBCTRL EOC-PD CCSJUMP
CCSXYMON.UCC.VCU.EDU WINUMDS CCSWSUS ARIESDC1
ARIESDC2 GOLDDC3 GOLDDC1 GOLDDC2 ARIESDC3
LCC-REMOTETOOLS AIM-MSS AIM-MSS-TEST
ORARMAN.VCU.EDU CERSEWEB DSS25 DSS26
LCC-FARONICS LCC-FARONICSDEV SOMIDDAS
TS-ALERTUS1 TS-ALERTUS2 TSBOMGARIC TS-SCCM1
TS-SCCM2 XMEDIUSFAX REOS.VCU.EDU
TS-MUNKI-PROD GOLDWEBMGR2 FMD-SIEMENS ADFS1
ADFS2 ADFSWAP1 ADFSWAP2 ADSJOB AUTODESKLMACA
AUTODESKLMADM DFS1 DFS2 ECOM1 ECOM4
JAMFPROSOM JAMFPROTEST JAMFPROTS MAAS360
LCC-PRINT SOMJOB SOMWEB1 SOMWEB4B SON-CONNECT
WVCW1 FMD-PMEXPERT BRIGHTONLOG KEYSTONE
BRIGHTON BRIGHTONDIFF FMD-NIAGARA4
NEWMON.TS.VCU.EDU TSIS-INFLUX.TS.VCU.EDU
CURIE MAGI IISHELIX SCHRODINGER
CUSIBM.VCU.EDU APOGEE.TS.VCU.EDU
APOGEE2.TS.VCU.EDU SOMWORLDPOINT.ADM.ADP.VCU.-
EDU VCUL-LOCKSS.VCU.EDU PANOPTICON.VCU.EDU
TSIS-WEC1 CCS-MAIL SCCMMBAM SCCMSCEP SCCMSITE
SCCMMDT SCCMDP1 SCCMWSUS SOP-NFSJUMP.VCU.EDU
MUNKI.ART.VCU.EDU FMD-SIEMENS2 AT-MSS-VSM
SCCMSQL1 SCCMSQL2
Node Group Name: BANNER_BLACKBOARD
Last Update Date/Time: 04/05/2018 10:38:04
Edited 1 time(s). Last edit at 2019-06-07 18:55 by Stefan.
Posted by: vbr | Date: 2018-05-17 18:09 | IP: IP Logged
Hi, I can confirm this error,
it happens even in an empty editor with hex-mode, searching for arbitrary text; the option "as text" doesn't matter; the presence of the matching content isn't relevant either.
Searching in regular hex mode (open as hex) works ok.
(Win 7 64bit, pspad 5, 277 32bit.)
regards,
