You are here: PSPad forum > English discussion forum > Disable auto insert of sample code
Posted by: larryralph | Date: 2018-05-11 17:35 | IP: IP Logged
First off, I use PSPad a lot. My favourite editor.
One option I would like to disable though, is the insertion of sample code.
Currently I am writing some Batch code. When I start typing, for example, an ECHO statement it is automatically filled in with extra and new lines of code.
Is there way to turn off this feature? I've checking settings a few times and I'm just not seeing it.
Thanks
Posted by: vbr | Date: 2018-05-11 19:23 | IP: IP Logged
larryralph:First off, I use PSPad a lot. My favourite editor.One option I would like to disable though, is the insertion of sample code.
Currently I am writing some Batch code. When I start typing, for example, an ECHO statement it is automatically filled in with extra and new lines of code.Is there way to turn off this feature? I've checking settings a few times and I'm just not seeing it.
Thanks
if this is the autocompletition function, which you'd like do disable, there is a dedicated setting:
Settings: Program settings: Editor (Part 2): Autocomplete delay [ms]:
the value 0 disables this functionality
You can still insert codeclips manually, typically with Ctrl+Space.
hth,
