You are here: PSPad forum > English discussion forum > macro command - F3 (find+next)
#1 macro command - F3 (find+next)
Posted by: ppetree | Date: 2018-04-30 14:09 | IP: IP Logged
Is there a way to insert the F3 (find next) into a macro? It doesn't get recorded (for some reason) and I can't find a key or command reference I can manually insert into a macro.
P.
#2 Re: macro command - F3 (find+next)
Posted by: vbr | Date: 2018-04-30 14:53 | IP: IP Logged
unfortunately, it is currently not possible to handle searching etc. with a macro.
A more comprehensive handling is available with scripting, but it is also more complex to code.
regards,
