You are here: PSPad forum > English discussion forum > Re: Code Explorer windows auto expand
Posted by: Coneman | Date: 2018-04-26 09:57 | IP: IP Logged
Since PSPad v5.0.0 the code explorer window is auto expanding all child nodes when pressing refresh. For xml files with 10k lines this auto expanding takes more than a minute. PSPad is not responding during the auto expand and the auto expand can't be stopped. Only when the whole process is finished it's possible to hit "Collapse Child nodes".
This was not happening in previous versions of PSPad.
Is it possible to deactivate the auto expand feature? I couldn't find an entry in the settings.
Posted by: pspad | Date: 2018-04-26 10:10 | IP: IP Logged
You are right. I will change behavior for XML. I can expand top level or first 2 levels only.
Posted by: Coneman | Date: 2018-04-26 10:41 | IP: IP Logged
Top Level would be fine for me or having an option in the settings to de-/activate auto expand to most granular level.
Posted by: pspad | Date: 2018-04-26 11:47 | IP: IP Logged
I just tested and modified Code explorer behavior. For XML I will expand first 2 levels.
It will be done in thread, so it won't prevent you to work in PSPad.
Posted by: Andreas | Date: 2018-04-27 11:08 | IP: IP Logged
Can you also please revert to the old behaviour that PHP code explorer opens the class tree automatically? This behaviour gets lost in version 5. I already asked for this some time ago but cant find it anymore. Since then I'm waiting for this.
Posted by: pspad | Date: 2018-04-27 11:56 | IP: IP Logged
Andreas:Can you also please revert to the old behaviour that PHP code explorer opens the class tree automatically? This behaviour gets lost in version 5. I already asked for this some time ago but cant find it anymore. Since then I'm waiting for this.
Hello. next time call more loudly.
Fixed. It wasn't intentionally. There was new main node "labels" added and PSPad expand it instead of the classes.
Posted by: Andreas | Date: 2018-04-27 16:36 | IP: IP Logged
pspad:Hello. next time call more loudly.
ROFL No, I'm too decent for that
Thank you very much.
