You are here: PSPad forum > English discussion forum > Re: Text-Diff (intern)
Posted by: hhoefling | Date: 2018-04-16 11:36 | IP: IP Logged
The Text-Diff is not functional.
It highlight the wrong text.
Sample: Make a File
1111
2222
3333
Open it.
Insert a line after the "2222"
1111
2222
---2a2a2a
3333
Call Diff with original file
Testet with 5.0.0.(267) 64 Bit
by HH
Posted by: Andreas | Date: 2018-04-16 12:02 | IP: IP Logged
I can not confirm this with 5.0.0 (271) 32 Bit.
Edited 2 time(s). Last edit at 2018-04-16 12:03 by Andreas.
Posted by: hhoefling | Date: 2018-04-16 15:21 | IP: IP Logged
Look at
upper Window pspad32-4.6.1
lower Window pspad64-5.0.0.267
by HH
Posted by: pspad | Date: 2018-04-16 16:01 | IP: IP Logged
I will test it in x64 version
Posted by: hhoefling | Date: 2018-04-17 07:09 | IP: IP Logged
PSPad 5.0.0.267 32Bit has no Problem, it works like the 4.6.1
by HH
Posted by: khagaroth | Date: 2018-04-21 08:36 | IP: IP Logged
The diff in 64bit version is completely broken (aside from producing wrong results it also crashes quite happily). It was already reported several times in the developer builds threads btw, since it was like that from the very start, but somehow it got completely ignored.
