You are here: PSPad forum > English discussion forum > V4 (2750) - how do copy/delete current line ??
#1 V4 (2750) - how do copy/delete current line ??
Posted by: Gorlash | Date: 04/03/2018 20:32 | IP: IP Logged
I am used to being able to copy current line by pressing Ctrl-C, without highlighting anything. Similarly, I could delete current line with Ctrl-X, again without explicitly highlighting the line.
I had asked about this topic in the past; at the time, and got the following instructions:
Program settings / KeyMap : Edit
Cut - Ctrl-X
That was working with V5, but with V4 it does not, at least not by itself.
Is there something else that I need to set or change to make this work?
I looked through the other options (including Direct Edit) and don't see anything that I recognize as relevant, but there are alot of options there!!
#2 Re: V4 (2750) - how do copy/delete current line ??
Posted by: pspad | Date: 04/03/2018 20:38 | IP: IP Logged
Program settings / Editor 1
Extended Copy/Cut
#3 Re: V4 (2750) - how do copy/delete current line ??
Posted by: Gorlash | Date: 04/03/2018 21:35 | IP: IP Logged
Excellent!! Thank you very much!!
(purr purr purr...)
