You are here: PSPad forum > English discussion forum > Re: regex question
Re: regex question
#1 regex question
Posted by: ppetree | Date: 2018-03-22 16:30 | IP: IP Logged
I have a file that is one very long line. Each section of the line starts with 0: like this:
0: text 0: more text 0: still more text 0: error 0: console.log 0: more text
I want to replace the 0: with a newline \n
I've turned on regex, tried searching for 0:, \0:, \0\:, ^\0\: and most every other thing I can think of. I manage to get it to replace the very first 0: on the line and nothing else. The box stays up with Yes, skip, no, Yes to All etc and I can keep clicking Yes but all that happens is the cursor moves to the right on the newly created blank line. Once I hit "Yes to All" just to see what would happen and I had to pop up the task manager and kill pspad.
Any suggestions?
#2 Re: regex question
Posted by: vbr | Date: 2018-03-22 20:33 | IP: IP Logged
ppetree:
...I want to replace the 0: with a newline \n
with reagrds to newlines handling, there are some limitations in PSPad, for both searching and replacing.
In this case a workaround can help, you can just use the mentioned pattern, but before that, the cursor must be placed at the and of the file and the search direction in the dialog would be "backwards".
hth,
#3 Re: regex question
Posted by: Andreas | Date: 2018-03-23 12:52 | IP: IP Logged
Yes, you need to do a backwards replace but cursor must not be at the end, can also be at the beginning.
Or you can use the addon phreplace. This is more comfortable, faster, more stable and with a higher performance.
#4 Re: regex question
Posted by: ppetree | Date: 2018-04-30 14:06 | IP: IP Logged
Thanks for that guys... searching backwards did work. smiling smiley
