You are here: PSPad forum > English discussion forum > JSON - separate a list of objects [{},{}] inside an array in code explorer
#1 JSON - separate a list of objects [{},{}] inside an array in code explorer
Posted by: michael.hollstein | Date: 03/19/2018 14:35 | IP: IP Logged
In code explorer, I can't see that there are many objects inside an JSON array and I'm not be able to expand separate objects.
Example JSON
"VM": [
"Name": "server1",
"Alias": "vm-server1",
"Volumes": [
"Path": "/dev/ubuntu-vg/server1-disk",
"Size": "8.00g"
"Path": "/dev/ubuntu-vg/server1-swap",
"Size": "128.00m"
Code Explorer Output is
v Volumes
Path
Size
Path
Size
Code Explorer Output should be
v Volumes
v
Path
Size
v
Path
Size
Edited 1 time(s). Last edit at 03/19/2018 14:38 by michael.hollstein.
#2 Re: JSON - separate a list of objects [{},{}] inside an array in code explorer
Posted by: michael.hollstein | Date: 03/19/2018 14:55 | IP: IP Logged
If you copy the JSON into this parser, you can see what I mean.
json.parser.online.fr
"VM": [
"Name": "server1",
"Volumes": [
"Size": "8.00g"
"Size": "128.00m"
